Button Wizard Problem
September 14, 2005 12:00 AM
Aaron,Thank you for the reply.Under the frames tab in the Title Properties window Frame styles says "no frames".Yes, I have a page selected in the left hand column.I tried opening a new blank title from the title wizard with a single page at 780 x 640. Tried to insert a 25 x 25 button using the button wizard and still have the same error.Any suggestions?Thanks,Griffin
