Audio Probs
June 1, 2007 12:00 AM
The trouble with that as a solution, is the fact if you play the audio on a PC where it works fine, you will have these inconsistent blank spaces.Does Trivantis have anything to say on this matter, or will silence be golden?Using other tools - and including building content in pure HTML via Dreamweaver, I have not had this problem occur.I did think of the silent space to be honest, however it sometimes cuts off at the end of the audio as well Bugger!
