Audio problem when run online
This sounds like a problem I ran into a while back while building a custom pre-loader for one of my courses for global deployment. What sounds like it is happening is that the flash file is starting to preload the audio, and then after the code is executed it actually does then "starts to play", but they have auto play on. (Hence why this happens the first time, its caching the file)
What you need to do in Flash, is change the code to turn off autoplay of the sound object, and then then modify the code so that you have a listener that executes the code and plays when everything has initialized properly.
