@afzalraza
February 6, 2009 12:00 AM
Check out Audio Control - One for Entire Unit
Adding Radio Buttons and Check Boxes
Do mathematical functions work in lectora?
Accessing FLV in network
Creating your own custom buttons in Lectora
Using Cue Points
Loading problem
Cue point limiatations in FLV files
Problem in locating the flv files
Audio problem when run online
Importing pages from an existing title
Online problem
MP3 audio problem
Lectora page with a table
FLV problem
Printing the content of a text block
Fixed Timer
player controller bar
Flash file issue
Chapter Completion status
Rollover text issue
Audio Problem In HTML Publishing
Index page problem
flash problem
Test Results Issue
Audio in HTML
global audio problem
Menu Problem
Progress Bar problem
Audio Issue
Text Block Query
Object Transition
mouse pointers in Lectora 2008
Audio Control
Progress Bar Problem
Line spacing in Text Block
How to create a pop up window in lectora
