Audio Control
January 21, 2009 12:00 AM
To my knowledge there is no Lectora action that will mute the sound. That is part of the player. You would have to modify the player. Maybe in Flash you can do that.You did not say so, but I am guessing that the progress bar is part of the player. You can create your own progress bar which will continue. Would that work?
