AICC course not running in Kaplan
Hi,I have received a mail from the client regarding the error they are facing in our Lectora based AICC course version 2.2. Version 2.2 is set manually in the crs file.For your information, I have checked the following items in publish settings: The publish course will reside on the same network…. The publish course will be presented in a separate window… The publish course will prompt to restore the last viewed location…. The mails states: Based on the current installation of the Kaplan content, we have found that the courseware is exposed to the internet, and therefore can be accessed without authenticating into the LMS. To mitigate this issue, we attempted to move the Kaplan courseware under a more secure IIS directory. Unfortunately, in doing so, we found that the content did not work. Below is a description of the issue, which I was hoping you could weigh in on to help us address this problem.Current Setup - undefinedThe content can then only be accessed via the LMS after authentication. However, the content fails to run, throwing errors. Please advice on the what needs to be done/configured in my Lectora source file to make certain that the course runs successfully on the client server/LMS.
