Adding to variable checkbox tick problem
Thx for your help1. gotcha2. I dont care about the other possibilities but do care about nulls - how do you test for them and prevent them?3. Your tools page was not all informative - what do you suggest if radios are not optimal? Whatever they are, do they need to be in a form if I am not submitting them?I cannot see how you can set Yes to add 1 and No to not add 1 at the group level. How can you get rid of the On Select actions? Where do you put the actions?4. Yes do not need retained variables - can drop.5. Separate button because when the four actions are put on one button the variable increases everytime I click it to renew the display which I dont want.6. 2006 - mentioned this in last postLaterD
