Adding to variable checkbox tick problem
November 3, 2006 12:00 AM
Wow. What a shock here!!! I had no idea as I have never done this before. Now you are learning why you try it out with a few rows before you build a whole page. Here is what I did on my copy. - I changed all third bullets from 2 to 3 (two in each row)- Changed actions that test for =2 to >1Now to save you some time back, If you copy the entire page instead of actions and boxes, Lectora retains Add to variable, instead of replacing with Set Value. Unfortunately it changes the names of all the radio buttons and that will happen regardless of how you do this because it needs a unique value for each group.
