Web Link doesn';t open a Web Link
August 10, 2011 12:00 AM
Hi Everyone,
I have some answers to your questions:
Calleyh - have you tried updating your Flash Global Security settings to "Always Allow" or create an exemption?
ods- There's no need to reinstall the trial, try re-enabling the ribbon. The re-enabling process depends on your version of PowerPoint, this link should be able to help: http://msdn.microsoft.com/en-us/library/ms268871(v=vs.80).aspx.
jmt200- a "www" entry is required for Web windows.
I hope this helps,
Stephanie
