vertical spacing between lines
January 3, 2008 12:00 AM
Ok, start a new title and create 4 text boxes on a page. In each text box type say about 3 lines. Make the text size 7 in one box, 8 in another, 9 in another and 10 in another. Now preview in html - IE 6 service pack 2.You will notice that the vertical line spacing (the vertical white space between the lines of text) is different for the last line when the text size is 7,8, and 9. It sorts itself out for 10. In case u can't replicate, there is greater space between the penultimate line and the last line, the others are fine. This is causing me grief. Reasons? Cure? Running Lectora 2007 SP4 (4766)cheers
