Variable/Dynamic Text Help
February 6, 2008 12:00 AM
Likely not be able to help you. See if you can isolate the page and strip proprietary stuff from it. Can you replicate the problem in a clean title? If so, send that.Likely not be able to help you. See if you can isolate the page and strip proprietary stuff from it. Can you replicate the problem in a clean title? If so, send that.
