Problem With Users Cheating
Hi Rob,
Have you tried to publish your title with the Protect Published Content option selected? You can find this option on the Options tab when you publish. This setting will disable the right-click menu from appearing and will also disable copying and pasting using Ctrl+C and Ctrl+V, which I believe covers your two main issues. Of course, a user intent on cheating can find some creative ways to accomplish this, but the Protect Published Content option should prevent them from using the most common methods.
