variable help
February 21, 2008 12:00 AM
James, It really seems to me that from what you've described, this is happening:1) The page loads, and when it does, it checks to see whether your variable meets all of the conditions. Naturally, at this point your variable doesn't meet all the conditions, so your Continue button does not show.2) Your learner selects all the buttons and the variable is altered properly (you can tell if this is happening by displaying the contents of the variable as Ben suggested above). 3) Nothing. You haven't told Lectora to re-run the Show ContinueButton action, have it check all the conditions again, and show the Continue button if the conditions are met. This will not happen automatically.I do hope this helps -- I'm not trying to be combative, just trying to help and test my own imperfect understanding at the same time. And my understanding is that when you assign an action to the On Page Show, it's going to just run the once and Lectora does not keep running that action (which means it does not keep checking those conditions for you).
