variable help
February 21, 2008 12:00 AM
Thank you all soooo much for your help and being persistent. This is by far the best forum I've been in to date :)I ended up taking Judy's advice from #1 above.I added a Next Page link on the nav bar that isn't active until all conditions are met. I wanted to have it look inactive, but that presents the same problem I was having before with the continue button since I think I'd have to do an On Show action with the page itself, so to make things easier on myself I added a on mouse enter "callout bubble" that tells the user the link won't work until they're finished.I added an additional on mouse enter callout that tells them they can move forward by using the link (added a change contents action on the next page link). The callout changes once all conditions are met (same as making the next page link active). I doubt that makes sense... but I'm in a hurry (deadline)!On a sidenote, I wish I could set an on mouse enter action to text, so I don't have to create an image for it to work. Am I missing something on this?Thanks again for all your help.James
