Login Sign Up
ELB Learning Logo
Topics
Members
Website
Knowledge Base
New Topic
Menu
  • Topics
  • Members
  • Website
  • Knowledge Base
  • New Topic
Archived
Report Abuse
variable help
@jamesmcoats
February 21, 2008 12:00 AM
Add actions to display 1starVAR just before you test it and after a couple of the Add to Variable actions. See if it has the proper value. Add actions to display 1starVAR just before you test it and after a couple of the Add to Variable actions. See if it has the proper value.
James Coats
@jamesmcoats
View Profile
More From James
Test Problems (part 2)
July 25, 2008 Reply 0 Upvotes
Test (Grading) Problem
July 19, 2008 Reply 0 Upvotes
Next/Previous Page links not working
June 30, 2008 Reply 0 Upvotes
Join The Discussion
Sign Up Login
