variable help
The issue you have James is that with your approach, the learner could click on one item multiple times and increment the count to 10 and then it would show the continue button. No good. Diane's solution sounds like it would work and is pretty clean.How do you change the gray star to a gold one? Are you using a show or a change of contents and what are you using variables for?
