Using xml to populate Flash for Lectora
Hey all,New to using Lectora and already have a question. I did search, but not really sure how to word it to find what I need.Anyways, I have a Flash file that uses an xml file to populate text in the swf. If I change the xml file, of course, Flash will update as necessary to reflect what is in the xml file.But when I bring the Flash file into Lectora, it seems to lose the connection to xml for Flash. Is this allowed? If so, please let me know because I cannot get it to work. Also, I'd like to have the xml file update the Flash object while while inside of Lectora.Anyways, I just need some help on having the Flash file update via xml while the swf is in Lectora.Thanks!
