Using xml to populate Flash for Lectora
November 2, 2007 12:00 AM
This is possible, and I managed to do it successfully recently. Make sure to pysically place the xml in the same folder as the flash file. By default this is the "images" folder.This is possible, and I managed to do it successfully recently. Make sure to pysically place the xml in the same folder as the flash file. By default this is the "images" folder.
