Using xml to populate Flash for Lectora
Sure would - attach all of your xml files at the title level as additional files (so they will be included when you publish out) then on each page where you have your flash file use the parameters tab (on the flash files properties) to add the flashvars parameter. I'm guessing you have the flash file set up to accept a string for the xml file it should use. Just as a sidenote, this only works when publishing to SCORM or HTML - not with .exe or CD's.Sure would - attach all of your xml files at the title level as additional files (so they will be included when you publish out) then on each page where you have your flash file use the parameters tab (on the flash files properties) to add the flashvars parameter. I'm guessing you have the flash file set up to accept a string for the xml file it should use. Just as a sidenote, this only works when publishing to SCORM or HTML - not with .exe or CD's.
