Using xml to populate Flash for Lectora
Two thoughts. First, rather than physically putting the XML file in the images folder, try attaching the XML file as an additional file at the title level (right click on the title icon - the three books - go to properties and use the additional files tab) This way when you publish out the XML file will be included - so if you try and publish to something else you don't have to remember to copy all of your XML files over.Second, if you are passing flash the name of the XML file to use you can do that through the parameters tab on your animation. So as mentioned above attach your XML files as additional files at the title level, then on the parameters tab of the animation create a new parameter with "flashvars" in the first field and "yourVarInFlashToHoldXMLFileName = nameOfXML.xml" in the second field. Hope that helps.Edited By: Hemingway on 2007-11-2 11:54:24
