Using Web Window by Snap! inside Lectora
Hello, I used Snap! to create a web window for a discussion on our company SharePoint site. When I published, it created an index.htm document as well as a swf file. I want to take this and put it inside a Lectora course I've already created. I tried adding the swf file, but when published and viewed in a browser the web window loads blank. So I tried copying the html text into an external html object inside lectora (not really expecting results, just testing) and that didn't work either.
Any suggestions? Is there a way to do this inside Lectora without Snap!?
Thank you!
