Using jQuery in Responsive project
Hello,
I'm using Lectora Inspire for serveral years and really often used jQuery to modify objects based on classes or names. That really worked perfect for me.
Now I'm new to Lectora Online, just started creating a responsive project. Of course first thing I do is adding jquery to the project - but unfortunatly it isn't working like it used to be. A short look in a published version: OK - Lectora publishs the content not (as it usualy does in an 'normal' project) as several generated html-files but as a bucket of js-files. I understand that this is the reason why I cannot use traditional jQuery selectors to modify the dom-elements.
Does anyone has an hint for me how to use jQuery in an responsive Lectora Course?
Thanks a lot...
Marco
Hi Marco,
When we released 3.0 with Responsive Course Design it did change our published output as you have noted. We use to have the HTML for the objects written into the page. Now we dynamically write the HTML for the objects at different points, so for a responsive title you may need to re-apply custom styles after a device rotation, or a view change in a PC browser.
One way to handle this is similar to how we do breadcrumbs or page numbers.
For example:
1. Set undefined to initially hidden.
2. Action -undefined
3. Action -undefined
I figured out that you have to put all the code in "$(window).load(function(){ });" so the code will be fired, when the completed page is loaded and displayed. In the past I always used the "$(document).ready(function(){});" - but this will be fired when the DOM is loaded, a bit too early...
This solution unfortunately has on side effect: The changes on the page will apply when it is fully loaded; so the user maybe will see the initial state of the objects.
Thanks Joe...
You're right - everything is possible... ;-)
