Using Actions
The problem is that OnDone actions for multimedia objects does not work on the Web because there is no guarantee which plugin will actually play the multimedia object. You either have to do external synching (know the length of the clip and just generate the transition to occur at a speciic time, or use a format that can trigger external scripts:WMA/WMV (which only works in IE (to trigger events)FLASH (but you have to code up your own trigger events in the flash).Tim V
