transition - fly right within a boundary
The graphic shows up from off the boundary of the course which looks odd. Is there a way to only show the graphic only when it's inside a boundary you can define like a mask that it only shows within that mask?
Also I find the wipe transition on text makes the text look blurry first before it finishes. Is there a way to change that?
Thanks,
