Login Sign Up
ELB Learning Logo
Topics
Members
Website
Knowledge Base
New Topic
Menu
  • Topics
  • Members
  • Website
  • Knowledge Base
  • New Topic
Archived
Report Abuse
Text alignment problems in 2008
@bjakman
February 27, 2008 12:00 AM
Noticed that too. Current workaround is to add a blank line with a space. If you don't put the space it will not work.Noticed that too. Current workaround is to add a blank line with a space. If you don't put the space it will not work.
bjakman Holcomb
@bjakman
View Profile
More From bjakman
Specify Additional Files location
May 13, 2009 Reply 0 Upvotes
XML Video Player on LMS
May 9, 2009 Reply 0 Upvotes
Separate size and position locks
April 18, 2008 Reply 0 Upvotes
Auto update conditions in a LO
April 4, 2008 Reply 0 Upvotes
Properties Window
March 6, 2008 Reply 0 Upvotes
Properties Window
Properties Window
Properties Window
Properties Window
Properties Window
Properties Window
Properties Window
Join The Discussion
Sign Up Login
