Text alignment problems in 2008
February 27, 2008 12:00 AM
Since upgrading from 2007 to 2008, I've noticed that text in multiple line text boxes are not properly aligned after loading them into our LMS. Most of the time, the sentences are bunched too close together.The only solution I have found it to render EVERY text box as an image. It's time consuming and it dramatically increases the file size, but it works.Is anyone else having this problem?
