Test Page Numbering Issue X of Y Not Consistent
I'm having a page numbering issue in tests in Lectora V16. I have a test with one section of 26 questions. I've told the test to randomize 18 questions. When I run the test in local mode, the page numbering is correct. Page 1 of 19 (counts the last page of instructions), Page 2 of 19, etc. But when I upload the page numbering goes Page 1 of 21, Page 2 of 19, etc. There seems to be no rhyme or reason. But it flips back and forth from 19 to 21 for the total pages. The actual count 1,2,3 is correct. Any ideas?
Discussion (2)
I'd simply replace the 19/21 variable in text with plain "19". It is probably easier to fix it this way and update the text in case the test setup changes later.
Thank you for answering. I went ahead and redid the test - thought it might be corrupt. It's working right now. But I will certainly keep your suggestion in mind if this ever happens again.
