Test not going to .Failed. page
December 13, 2008 12:00 AM
Yes, next button is deactivated until users gets correct answer or exhausts tries (2). Next button is inherit to the top and set to go to next page.The next page is determined by the test results - pass go to 'passed' page, fail - go to 'failed' page.What do you mean process the test on the last page? When setting a passing score in the test properties, the test should then determine if all questions were correct or incorrect, thus sending the user to page based on those results.
