Test not going to .Failed. page
You need an action that says Submit/Process Test/Survey to tell Lectora that you are ready to have the test score calculated. Usually this action is on the Next button on the last page. It is on the Done button that is generated automatically. Either way, you need to have one executed. If the Next button, that is all that is needed. You do not need Go To Next Page.Edited By: Ben Pitman on 2008-12-12 16:44:46
