Test not advancing after answering question
February 19, 2013 12:00 AM
Hello,
I recently upgraded to Lectora Version 11. I made a change to a course, and re-published to the same file. When I upload the file to my LMS, the questions will not advance after answering. The feedback pops up, but then it will not move on to the next question. The test was working fine in the old version, and I made not changes to the settings. The same thing happens when I publish to Scorm Cloud, so i don't think it is my LMS.
Any help would be greatly appreciated!
Just FYI - I just heard back from Trivantis IT. If, like me, you must be 508 compliant and cant use the LightBox pop-ups, they said, "Currently, the only other workaround would be using immediate feedback or placing actions on the next button to perform feedback like actions rather than using the feedback option."
I am worried about this because this workaround will be inconsistent with our other courses and it will add a lot of development time that I hadn't accounted for. But, Trivantis did say that it will be addressed in the next service pack. I'm hopeful that it will get resolved soon and that the other new features in Lectora 11 will save me some time so that this workaround doesn't add to my development time :)
No answer to your problem but be SURE to report to Support on the Lectora.com or Trivantis.com web site
I am having this same issue. I just heard from IT - "When you publish the course, can you select the Use Lightbox Pop Ups on the Options tab and see if that resolves the issue". It did resolve the issue for me.
The problem I have with this work-around is that I only do work for the Federal Government and must be 508 compliant. These pop-ups are not compliant so I need to find another work-around. I will let you know what the result is when I hear back.
