syncing audio
Chuck makes a good point. The audio editor only supports WAV and WMA files. The WAV files can be huge, and degrade online performance. The WMA files can be really tinny and of poor audio quality.I fought with trying to find a meaningful use for the audio editor and finally decided that manually entering a delay into bulleted text properties was the only good way to limit file size AND get reasonable quality. Even so, the timing -- while adjustable to a tenth of a second -- is only approximate. It varies from user to user, and even from time to time on the same machine. I'm pretty sure that is because the audio and visual component run as separate processes, so all the throughput issues -- server, Internet connect, user computer -- seem to help "have their way" with timing.Hope this helps!Dave
