Is this what you mean by "timing the bullets as they come in"? You time how long the audio runs to when you want a bullet to appear. Then you have an action to show a text block that contains the desired bullet with that amount of delay. I would use the audio editor in the Lectora Suite. You can put events in the audio and have it display text blocks when you want them to appear.
