SWF files and audio timing
This drove me crazy for a while, but I finally figured it out...In flash when you use audio you have the option to sync as: event, start, stop, and stream. Unless it is set to “stream” the audio will can get out of sync on slower machines/connections. By setting it to stream you ensure that everything occuring on the timeline is in sync with audio.
