Survey Questions not retaining selections in iframe
May 29, 2013 12:00 AM
Hello,
I have an issue using an iframe and survey questions hat I hope someone might have some ideas how to fix.
I have built a page that has an iframe that accesses another page in the title that has a series of yes/no survey questions. I am using the iframe to help with a "realstate" issue. Participants answer either yes or no questions to build a score. The survey questions work great by using varibales to set values and ultmiately a percentage score. However, if the participant leaves the page and the returns to review the survey questions again, the yes/no questions are reset to empty. The variables associated with the survey questions are retained, however this does not help participants review if yes or no was selected.
I have set the survey questions to retain between sessions and the survey question page to submit all questions. The problem does not appear to be a varible issue but more of survey questions being reloaded in an iframe page.
If this is just something within Lectora then I will build a workaround using the variables but I was hoping for maybe a quick fix a couple of ideas I could try.
IE9
publishing to SCORM
Thanks,
Jeff
