Some text blocks not rendering as images
July 30, 2008 12:00 AM
What happens when you render the text as an image, it needs to make a certain color transparent so you can see what is placed underneath it. Lectora looks at the background color to determine that. Therefore, if your default background color is black and the text is black, the text is actually in the image created, however, it is just transparent as the black color cannot be seen. If you are using the same background color for all your pages, try going into the Title Properties and change the color by selecting a custom color background. Just change it by one number in the chart so it will still look black to the human eye and when you publish out, all the text blocks that you have rendered as images should appear fine. The custom color option uses green, red and blue to set colors. I believe black is set to 0 for all three. Just change that to 1 for each and that should do it for you.What happens when you render the text as an image, it needs to make a certain color transparent so you can see what is placed underneath it. Lectora looks at the background color to determine that. Therefore, if your default background color is black and the text is black, the text is actually in the image created, however, it is just transparent as the black color cannot be seen. If you are using the same background color for all your pages, try going into the Title Properties and change the color by selecting a custom color background. Just change it by one number in the chart so it will still look black to the human eye and when you publish out, all the text blocks that you have rendered as images should appear fine. The custom color option uses green, red and blue to set colors. I believe black is set to 0 for all three. Just change that to 1 for each and that should do it for you.
