solution for tracking % complete
Amacadam, My page contents are different, but the call is in the same place. The only difference I see is that I don't have as many brackets around the call. See below for my code.If the call won't work for you, you might ask learn.com support. I don't think they had to modify anything for my client, but they might have. By this I mean, they might have to check a box that you are using this variable or something. That shouldn't be the case, but you never know.Also, what has been your experience with SCORM 2004? --function init() { findWH() if( is.min ){ if( parent.document != document) parent.document.title=document.title if( bInitSCORM ) { var oldLoc = AICC_Lesson_Location.getValue() if( oldLoc != '' && oldLoc.indexOf( '.' ) > 0 && oldLoc != 'a001_popups_test_1_landing.html' && oldLoc != 'a001index.html' && confirm( 'You have previously been in this lesson.nWould you like to return to the last visited location in the lesson?' ) == true ) { saveVariable( 'TrivantisEPS', 'T') ObjLayerActionGoTo( oldLoc ) } } if( window.name.indexOf( 'Trivantis_' ) == -1 ) AICC_Lesson_Location.set( 'a001_popups_test_1_landing.html' ) setTimeout( "preload( 'images/info_standard.jpg','images/info_active.jpg','images/ br_black_background_2.jpg','images/forward_standard_grey.jpg ','images/forward_standard_yellow.jpg','images/menu_standard _grey.jpg','images/menu_standard_yellow.jpg','images/help_st andard_grey.jpg','images/help_active.jpg','images/exit_stand ard_grey.jpg','images/exit_standard_yellow.jpg','images/didy ouknow.jpg' )", 0 ) button2485.init() button1644.init() button1643.init() button1642.init() button1641.init() text1684.init() text1683.init() text1680.init() image2496.init() text2497.init() button2485.activate() button1644.activate() button1643.activate() button1642.activate() button1641.activate() text1684.activate() text1683.activate() text1680.activate() image2496.activate() text2497.activate() action1690( ); action1689( ); action1688( ); action1687( ); action1686( ); action1685( ); if( location.hash ) { var newHash if( location.hash.charAt(0) == '#' ) newHash = location.hash.slice( 1 ) else newHash = location.hash location.hash = newHash } setTimeout( 'trivUpdateTOC( "a001_menu_menu.html", "a001_menu_menu.html", 1 )', 1000) }LMSSetValue( 'cmi.core.percent_complete', '33' ) }
