Showing and Hiding Entry Fields question
1. your last two posts are really not on the initial topic. It is better to start separate posts for each topic. 2. Expandable menus? Of course. Why don't you use the menu object? What problems does it give you?3. Framesets are hard to manage and very few of us use them. Why not just put the objects at the title or chapter level for navigation?
