Showing and Hiding Entry Fields question
March 9, 2007 12:00 AM
I don't know how big the entry field or button is, but you could consider moving it? Just create an action that moves the invisible button or field somewhere no user would ever dare to click, and make it move to its original coordinates once it has to be shown.I have to agree with ben though, it is a bit overkill for one page. My suggestion would be to spread it evenly over some pages, or create a page per field. You do use Lectora 2007, so creating the exact layout as the page before should not be more than 1 minute of work :) .If moving is no option, then perhaps you can arrange something with actions that let buttons be some sort of "dummy" buttons if no variable has been set first. Actions could be to show a white square on a whit background somewhere, with a "go to next page" or "show the next step" option in the ELSE statement.Hope this will help or inspire you.
