Showing and Hiding Entry Fields question
Well, my first take is that you have too much on a page. I would normally use multiple pages that to the learner look the same. The only suggestion I have is to cover it with a transparent .gif or text box with the Render as image checked. Then hide it at the same time you show the entry box.I just checked on 2006 with a hidden box and I could not click in it when it is hidden. Not sure why yours is active. If you can't get it, click the link below for free support.
