Setting Variable after a test
I set up a test, and then a section section in which I have a page with a matching question. I want to set up a variable that says "upon getting this matching question right, go to> chapter > chapter name."First, what do you attach the action to? the test page? The test section page? Then what is the variable you set up? I can't really figure it out from the help menu.I'm sure this is easy to do. Thanks in advance for you help.Barry
