Setting Variable after a test
1. Create your question. Look at question properties and on the third line is "Associated variable name:". You can use the Lectora name or change it to anything you want. I usually copy that name and put it in the first field "Name:" so that have it readily available for step 2.2. Put a button (or image or text block) on the page that has one action attached to it. When you click the button (or image or text block) the action is:On: ClickAction: GoToTarget: Chapter/Section/PageName: what everon the Condition tab of the actionVariable: Question variable from step 1Relationship: Is CorrectIf this is not clear, please post your questions.
