See correct answer for questions while in edit mode
December 17, 2020 12:00 AM
Probably the most often correction I have with assessments is accidentally NOT identifying the correct answer while creating the question (usually copy/paste questions from other pages, or using a test template where I have a set of questions already built. If the correct answer was visible in edit mode, this error would occur probably 90% less. (may not work for all question types, but seems it might be doable for multiple choice and multiple response at least).
