Search Engine for Lectora
When publishing for HTML you don't need to worry about setting the AU. You can just leave it as is. I determine weather or not the course is HTML or SCORM/AICC. I need the AU only if publishing to multiple AU's, if not, no need to change.
As for the error that you are recieving, it looks like something specific to a version of the browser, which version of IE/Firefox are you using?
Its been tested and working fine in IE 7,8, Firefox 3.5, Chrome. When you let me know what version you are using, I can better tailor a fix for this situation. (looks like the Javascript engine is not interpreting my code properly)
