Search Engine for Lectora
Hello Greg.
Thanks much for making this solution available.It will go a long way in making search capabilities available for learning modules created using Lectora.
I have a question regarding its use.
I followed your directions from the PDF document, and am not sure about the AU number a001 as I am publishing to HTML. Does that matter? What number am I using in this regard?
Secondly, after checking to ensure all external files were in the correct place, I published and tried on a web server. When I click the search button, the search window opens but nothing is displayed. Using Firefox I am able to see a HTML error message.
I receive the following error message.
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; GTB5; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30; InfoPath.2; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729; MS-RTC LM 8; OfficeLiveConnector.1.4; OfficeLivePatch.1.3)
Timestamp: Thu, 3 Dec 2009 23:02:27 UTC
Message: 'window.opener.top' is null or not an object
Line: 6
Char: 1
Code: 0
URI:file http://.../write_search.js
Not sure why the search window does not display the search box. When I view the source of this search page, the code is there, but it is not running in the browser.
Thanks in advance.
Bruman.
