Search Engine for Lectora
November 21, 2009 12:00 AM
There is no reason for me not using the Title Manager Frame.
However, there seems to be another issue that may be due to the course I used the search tool.
I went ahead and created a brand new course with a couple chapters and pages, inserted the search tool and it worked. I did not add the Title Manager Frame when publishing, and it still worked. Added the Title Manager Frame and it worked as well.
In the previous course I inserted the search tool, it has quite an extensive mix of External HTML objects with Javascript and I am wondering maybe one of my code is blocking the search tool from running. I did check the Title Manager Frame in the previous code as you indicated but the search code still did not run.
So I proved that it worked but not sure what was blocking the code in the previous course.
Bruman.
