Random Test Navigation Publishing Problem
Thanks for your reply.There is no Done button in the test.If you want to check this problem:1. create a button which should navigate to the any last page of the title.2. Add a dummy test with random mode.When you publish it you can understand the problem.ThanksRazzak
