Mastery score in manifiest file problem
EdT,Thanks much, that seemed to do the trick.I wanted to document what I did for other below:1) I had to setup a mock question for the test.2) I also 'unchecked' the 'Include in Table of Contents' on the Test Properties->General tab3) I also unchecked everything under the Test Properties->Content tab4) In Test Properties->Results, I checked Grade the Test (which revealed the Master Score) and Include Test Score in Overall Score.On publish (SCORM 2004), I got: 0. 75 Thanks again!
