Random Test Navigation Publishing Problem
Within a randomized test, you can only have navigation buttons with the actions go to next page or go to previous page because the course itself will randomize the questions internally and do the navigation for you. If you go outside of those actions and try to use your own navigation, it will override Lectora and its ability to do the randomization for you. What other navigation actions do you have within the test itself?Within a randomized test, you can only have navigation buttons with the actions go to next page or go to previous page because the course itself will randomize the questions internally and do the navigation for you. If you go outside of those actions and try to use your own navigation, it will override Lectora and its ability to do the randomization for you. What other navigation actions do you have within the test itself?
