Radio buttons not clearing
February 19, 2009 12:00 AM
Hi, Michele -Any chance your test question has "Retain question answer between sessions" selected (on the first screen of the Question Wizard)? That's the only thing I can think of that would cause the values to be retained once you've actually closed out the course...except...be sure you've restarted the browser and cleared its cache when you're testing this stuff. I was just dealing with some funky problems yesterday that were "cured" by doing that little routine. (Tip: Make sure that you've closed all of the browser windows before reopening one and clearing the cache.)If neither of these seem to be the fix for your problem, then the only workaround I can suggest is to put an On Show action on the page that resets the question.Hope this helps!Laura
