Tip for when pg not displaying in LMS
January 25, 2007 12:00 AM
Do NOT name your Lectora pages using a period. I named one "offensive lang." and it messed up the coding later causing LMS to not be able to display that page. Why? It ended up causing two periods side by side in the source coding ".."So, if you are having this prob...you might look to see if you named a page using a dash or a period in the name. After you fix and republish, be sure to refresh when you get to that page in the LMS.
